I'd like to run an executable file made with Labview 6i, on a PC but without having to install the NI-DAQ package. What are the DLLs I need to put next to my executable file or in the windows/system directory, in order to make it work?
Don't try to do this.
Install NI-DAQ it is for free with the card and solves more problems than you think.
greetings from the Netherlands
(2,692 Views)
Does your executable program need NI-DAQ (do you communicate with any data acquisition cards/devices)? If so, you need to install NI-DAQ for it to talk to the DAQ devices, there's no way around it.
If you didn't use any DAQ functions in your program, you should need:
* The runtime engine (lvrt.dll) which comes with LabVIEW
* You may need the serpdrv and daqdrv files that should have been created by the App Builder.
With these files in the same directory as the executable, it should run.
(2,692 Views)
