I did a example about TCP/IP,but the button of the server didn't act when the button of the client acted.
Perhaps my description isn't quite right,but if you saw
my vi, you will know my meaning.thx!
Message 1 of 8
(3,116 Views)
on your server vi you set the port number by a ring control, in your case you are setting 0 as port number. Use a standard numeric control to enter 3045, the same you do on the client vi.
Good luck,
Alberto
Message 2 of 8
(3,116 Views)
you are right ,thx
Message 3 of 8
(3,116 Views)
Your main problem is the fact that your port is not a constant but a ring control.
Another tip: you can easily send and receive booleans directly by typecasting them to and from string, no need to jump through all these hoops with formatting and case structures. See attached image for an example.
Message 4 of 8
(3,116 Views)
thank you very much,I have a request for your email.
I saw your profile,you are experienced in using Labview,I have some questions about my thesis.I can?
Message 5 of 8
(3,116 Views)
Sure, you can ask your question here, and everybody will try to help you.
I usually don't give out my e-mail address on a public web sites because they often get harvested by bots for spam lists. I've done quite a bit of TCP/IP and you are welcome to contact me directly at the address given below.
Message 6 of 8
(3,117 Views)
I have a problem with my final year project. Which I required to make an interface between the wifi device and PC's by using tcp/ip. I don't have a idea how to do it because at the transmission side it will directly transfer the data after receive my command. Can you help me out of this problems?
regards,
MF hussin
Message 7 of 8
(2,921 Views)
Hey MF hussin,
    I'm not sure we understand your question.  Have you been trying to do this in LabVIEW and have run into a problem?  There are some examples of using the TCP VIs in the Example Finder that ships with LabVIEW.  Also, here is a Developer's Zone article about TCP in LabVIEW.  I hope this helps.
Brian B
Account Manager
Message 8 of 8
(2,899 Views)
