IS it possible to make every second value, plotted to a chart, to get a different colour from the first value!
Hi to all
I got this chart witch plots values from a multimeter, Parallel with that I control a switch to my home made HW, so the multi meter measures a current when the switch is on and Volt when Off. The chart cant see diffence between these two measurements so I need the chart to plot the Current in one colour and the Volts in another colour. Can I find proberty for the chart that can manage that???
Zamzam
HFZ
(2,541 Views)
I'm not sure if this is what you are asking for, but check out this thread 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,510 Views)
Thanks TiTou
That was a lot of help!!
U are the supreme!!
Zamzam
HFZ
(2,475 Views)
