I do not have these VI's Functions»Mathematics
I have the full development 5.1.1 package of Labview. The help directory indicates that I should have these mathematics vi's. In particular I am looking for the median mathematics vi. I looked on the full development cd but could not find any of the vi's. Where might these mathematics vi's be located with the full development system? When I look in the functions pallet they are not there, nor are they in my labview dir.
(2,570 Views)
In version 5.1, median is found under the following palette:
"Mathematics..Probability and Statistics" in the lower left corner.
If you don't see it, got to menu: "Edit...Select palette set", make sure "Default" is selected. (If it is set to "Basic" many advanced things won't show in the palette.)
(2,570 Views)
btw: if you still don't see it, try to reinstall and make sure to select the full (and not minimal) installation option.
(2,570 Views)
Hey that was the trick, thanks alot, pretty simple after all. Guess I should have looked around more. Wonder why they didn't put that select pallette set in the windows drop down. Next time I need to look around more. Thanks again.
(2,570 Views)
