reading subset of data from LVM file
I'm recording multi-channel data from a DAQ device with the 'Write LVM File' vi. After recording we want to 'play-back' the data to a graph display and select certain parts of the dataset interactively (eg setting start and stop time with cursors). The selected part will then be exported to a spreadsheet file. Is there any known example which we could adapt to our needs?
(2,702 Views)
which version of LabVIEW are you currently using?
I've knocked up an example in LV 7.
Hope this helps.
Sacha.
// it takes almost no time to rate an answer Smiley Wink
(2,702 Views)
Sacha - That's what I was looking for. Thank you so much!
(2,702 Views)
