I do not know why bundle by name is not working
I am trying to simulate signals and save these signals into the Citadel database using DSC module. I am following the example in the LabView but when I try to connect the bundle by name to waveform component, it shows that they are not able to be connected. I am wondering what makes connections between these two unavailable.
(1,860 Views)
Accepted by TimK0315
Did you name your element in your cluster constant?
GCentral
(1,855 Views)
It needs a name to use Bundle by Name. Right click on the 0.001 constant and click "Show Label", then name it something useful.
(1,850 Views)
Thanks. I can make a connection now.
(1,848 Views)
