Order analysis without the order analysis tools is really only possible if the machine is running at a constant speed. Simple track the running speed, then do an FFT, harmonics of running speed (the 10th harmonic is the 10th order) are what you are looking for.
If the machine changes speed during normal operation, changing loads, changing functions, you will need to sample your data aligned to angular position, or use the gabor transform offline to track harmonics of rotational speed. These are the key functions supplied in the Sound and Vibration Measurement Suite.
Let us know how it works out.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
