Preferences for source control
Hi, I'd just like to get some input on what people are using for source control and what their likes and dislikes are. We are currently evaluating Perforce, and things seem to be going OK. Is there anything I should be looking out for?
Thanks.
Message 1 of 11
(4,143 Views)
Check out this developer zone article...http://zone.ni.com/devzone/cda/tut/p/id/4633
As long as you are using the LabVIEW Professional Development System, you can integrate your source control into LabVIEW.
Rational ClearCase is the tool I am using, but I only have the Full Development system so it isn't integrated.
ClearCase is fine, but using it for LabVIEW without having the Professional Development system is a pain.
Message Edited by Troy K on 03-11-2008 10:33 AM
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 2 of 11
(4,133 Views)
Hi Sima,
I ve used MS VSS with LV 7.1 externally.
Now, it gets configured into LV 8.5 seamlessly without any problem. Smiley Happy
In general, MS VSS is enough unless & until there are so many development teams working across globally; because it is said that it has some serious problems with networks.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 11
(4,121 Views)
Thanks for the replies.
We've sometimes noticed that you have to refresh or go to Perforce and Get the latest revisions manually, even after you Check Out a file, which I thought would automatically get the latest revision. Is this normal? What buggy things happen for you in ClearCase or MS VSS?
Also, can you comment on the administrative side of either one? Perforce seemed pretty easy to install server-side, and hasn't required much administration so far. We are a small group, so we don't have a separate administrator for source control software.
Message 4 of 11
(4,106 Views)
Does anyone know whether TortoiseSVN is integrated into LV, or do you have to check in/out from its interface in Windows Explorer?
Message 5 of 11
(4,083 Views)
Hi Sima,
If you want more information about Using Source Control Software with LabVIEW this is an awesome tutorial
Hope this information helps a little bit
Van L
NI Applications Engineer
Message 6 of 11
(4,077 Views)
Hi Sima,
We re also exploring the possibility of integrating TortoiseSVN in our company.
From the presentation we had a few days back, it appears to be encouraging to be integrated into LV itself. But, I m not so sure as of now.
I shall update here once we re thro' the entire process.
Message 7 of 11
(4,072 Views)
Tortiose SVN is a standalone client for Subversion. It does not integrate with IDEs (including LabVIEW). It is an extension for Windows Explorer.
George M
Message 8 of 11
(4,068 Views)
Hi George,
Thanks for the info. Smiley Happy
I thiunk the power point presentation was not clear to me completely. Smiley Wink
Message 9 of 11
(4,051 Views)
In order to use SVN (the SCC behind TortoiseSVN) inside LabVIEW, you will need a proxy.
PushOK is one of the options. I use it myself and it works just like MS VSS at work.
Ton
My LabVIEW Ideas
Message 10 of 11
(4,044 Views)
