I find a vehicle model in LabVIEW not Simulink model.
Hi.
I find a vehicle model in LabVIEW. I don't want to use Simulation Interface Toolkit.
I tried to use simulink dll vehicle model using Simulation Interface Toolkit. But these method had a some problem of delay.
So I directly want to use vehicle model in LabVIEW.
And I also tried to convert simulink dll file to LabVIEW vi file using Simulation Module.
But in these process, all dll functions did't be converted. Bcoz dll file consisted of state-flow, integrator, derivate and etc.
If anyone has the vehicle model in LabVIEW, plz contact to me.
(3,452 Views)
Hello Joey Lee,
I am not sure what you mean by vehicle model in LabVIEW… are you referring to using the Engine Simulator Starter Kit? Or might this forum post about using non-linear systems in the Simulation Toolkit be more along the lines of what you are referring to?
David G
Sales Engineer - SE Michigan & N Ohio
(3,412 Views)
Thank you for your reply.
I want to simulate vehicle dynamics using LabVIEW. And I have a vehicle dynamic model in simulink mdl file.
I tyied to simulate vehicle model through the SIT.
But I want to simulate the whole vehicle model using LabVIEW, so I searched simualtion module.
Simulation module has a simulink translator. Then I translated simulink vehicle model to LabVIEW function.
But some blocks doesn't be translated. So I want to find a whole vehicle dynamic model.
(3,398 Views)
Hello Joey Lee,
The Control Design and Simulation Module v 8.6 does not support certain features in .mdl files. Please have a look at this linked document, and ensure that your .mdl file does not contain any of these features. I hope this helps 🙂
David G
(3,380 Views)
