Storing refnum of an open TDMS file in private data member
I have created a simple class for datalogging.  I am using TDMS and when I open a file I would like to store it's refnum in a private data member.  I can not find a compatible refnum type to store this into.  Any help would be appreciated.
(2,585 Views)
If you right click on the ref output of the TDMS open function and select create control this will give you a compatible refnum control. You can then copy/paste this into your objects private storage.
(2,575 Views)
Worked like a champ!  Thanks again.
(2,573 Views)
I use this trick for creating many of my controls as I know the data type will be correct. It is quite useful, especially for esoteric refnums (user event especially).
(2,563 Views)
