I get "error of type 2046700" when running my executable on the target machine
I have a vi using Vision routines. I compiled an executable which runs fine when installed on the machine with LabVIEW on it. On the target machine however I get : "VI has an error of type 2046700. The full development version of LabVIEW is required to fix the errors". It was built using the full development version of LabVIEW 7.1 and IMAQ VISION 7.0.0.
Thanks in advance.
Certified LabVIEW Developer (CLD)
(2,957 Views)
Hi Manuel
You need Vision Run Time engine to be installed on the machine to have it run an exe containing vision.
Did you install it ?
(It is not free...)
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,957 Views)
Ah, I didn't realise, I thought the regular run time engine with the application builder took care of that.
Thanks for the help.
(2,957 Views)
