Labview Date to SQL Server DateTime Conversion
I have inherited a database of legacy data (created by Labview software) and I need to import that data into a SQL Server 2000 database.
One of the fields I'm importing includes a string of numbers which respresents a datetime field - in the following format:
3172089659
which represents the number of SECONDS since Jan 1 1904 12:00 am Universal Time
(Was that a significate date in history ?)
Is there a built in function within SQL that can help be convert this into a standard SQL Server DateTime format during import?
Thank you
Devon Kyle
(3,078 Views)
Devon,
This can be somewhat database dependent. I don't know how the standard SQL Server handles date addition. However,most have it. One which I uses has the following:
SECONDS( datetime-expr, integer-expr ) Add integer-expr seconds to the given date/time. If the integer-expr is negative, the appropriate number of seconds are subtracted from the date/time.
Since you know the start date, this would easily calculate the date you are wanting.
Hope this helps.
Russ
(3,078 Views)
