I get this error detail when building my Installer - CDK_Item_OnDoProperties.vi.
I am upgrading an application from LV 8.5 to 2009.  I am able to build the EXE.  But when I build the Installer, I get the following error:
The following file(s) are not found on the system:
<Not A Path>
<Not A Path>
Click on "Details" and get........
CDK_Item_OnDoProperties.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Engine_FileExists.vi
Thank you
(2,752 Views)
Go through all the threads here
and post back whether that helps in solving your problem.
Mathan
(2,743 Views)
