I have USB webcam from NI but i donot have it drivers
Please post a picture of your camera.
Or try a image search in google with USB camera as keyword and try to get the name of it.
Hope it helps!
Mathan
Message 11 of 24
(1,974 Views)
this is the image of my webcam .
Message 12 of 24
(1,970 Views)
Hai,
I was able to locate it in google. Its an infrared usb pc camera. but unable to find its model no and specifications. some kind of server problem here.
Edit: It's the second one right?
Message Edited by mathan on 08-01-2008 04:04 AM
Message 13 of 24
(1,961 Views)
Infra-Red USB PC Camera
(Model No. CM-01)
Infra-Red USB PC Camera (Model No.: CM-01)
This Infra Red USB camera has an effective IR distance up to 2.0 meters.   The clipper allow it to be attached to any protruding object and it's adjustable neck allow it to be rotated to any direction.
Specification:
  • Infra Red LED for night vision, effective range: 2.0 Meter
  • Anti-slip clip on with adjustable neck.
  • Dimension: 35 (W) x 75 (H) x 57 (D)
  • Net Weight: 150g
Message 14 of 24
(1,944 Views)
And the driver files are here. Download. Post if any other specific help required.
Mathan
Message 15 of 24
(1,943 Views)
you had replyed me that the driverfiles are here but i couldnot find it so plz give me the proper linc
Message 16 of 24
(1,940 Views)
sorry. forgot the attachment.
here
Hope it helps!
Mathan
Message 17 of 24
(1,937 Views)
thank you for giving me the good linc of the drivers for my cam. now my cam is detected but still i m unable to capture the images from this cam. is it possible that windows does not support this driver? or what could be the problem
i m giveing u the driver which i had installed.
Message 18 of 24
(1,929 Views)
Hi ddsdds,
how do you try to get an image? What does it mean the cam is detected? Can you use a program shipped with the driver with which you can capture images? Please explain what you have tried til now. Do you want to use LabView? Which Version? Did you install the IMAQ USB driver?
Mike
Message 19 of 24
(1,919 Views)
I think you missed the attachment. If you preview post, then your attachment will gets losed.
Mathan
Message 20 of 24
(1,918 Views)
