I have a LAbview 8.6, and i can´t open a file from a Labview 5.1.1
How you do it depends on the protocol that the manufacturer implemented, and whether or not they provided a DLL. If they provided a DLL then you need to use the Call Library Function to talk to the instrument. You should start here: USB Instrument Control Tutorial.
Message 11 of 19
(1,681 Views)
                 Hello!
                 Here we go again.
                 I am with the same problem one more time.
                 If anybody could please save these VI in a more recent LabVIEW version I would be very grateful.
                 Thank you.
                 Carlos.
Message 12 of 19
(1,619 Views)
Message 13 of 19
(1,616 Views)
                     Thank you very much!
Message 14 of 19
(1,613 Views)
I have the same problem. Can someone convert this?
Message 15 of 19
(1,545 Views)
Hi kivanc,
it would be ok to attach only the single vi, that you can't open (main_serialport.vi). All others already were converted to LV8.6...
But all share one problem: missing subvis from a different library.
Message Edited by GerdW on 10-08-2009 11:47 PM
Message 16 of 19
(1,539 Views)
Thank you.
Message 17 of 19
(1,514 Views)
Hi All,
I also have the same problem with a .llb from ICS Electronics.  Could someone convert it to 8.6.
Thanks In Advance
Martin
Message 18 of 19
(1,358 Views)
Marty H wrote:
Hi All,
Thanks In Advance
Martin
Please post in the upconvert thread. Thanks.
Message 19 of 19
(1,334 Views)
