I use it in parallel mode I can choose, in each channel, if the filter is ON or OFF.But when I use it in multiplexed mode only the filter in channel 0 can be selected.As NI recommands to use the second mode, I want to know how can I configure the filters ?Thank you for your answer, but in fact I would configure filters from labVIEW, may be by using NI DAQ thanks to call libary fonctions.
