I have a application that I must measure after 2000m secound
I design a new application in labview 6i which worh with NI DAQ ( pci-4451) this application measured THD .... this works very well but i want to add timer or counter to measure after 2 secound
(2,809 Views)
If I understand your question, you want measurements taken every 2 seconds; for a low resolution timing solution you could just place the measurement code in a while loop with a Wait Until Next ms Multiple.vi to control the loop interval.
(2,809 Views)
Hi :
may be you don't understand me .... i want to use timer to controll on my PCI-4451 ..
what i mean if I Create a sine sweep in my application using PCI-4451 all the time this sine sweep run .... what I want every 2 scound I want to measure the input
(2,809 Views)
Try the attached vi. The original vi is on developer exchange.
(2,809 Views)
Can your PCI-4451 generate an interrupt (DAQ event) that can be used
to tell your application when it has completed its 2 second sweep?
That would be the best way. Set up the card to sweep once every two
seconds on it's own and then have it signal the PC to collect the
sweep with a DAQ event. This would be similar to telling an o-scope
on a GPIB interface to do a two second long sweep and triggering it
from the host PC and telling the host PC to wait on the SRQ when the
scope is done with it's sweep.
If not, the best resolution you will probably get is about 10mS using
a standard LV timer. You could implement a MCI multimedia timer via C
code which is more precise (1mS) but it will eat up a lot of CPU.
Interrupts or DAQ events will be m
uch better because they are very
precise and don't eat up any CPU.
If you can't do this, perhaps you can use some external dedicated
hardware to generate an interrupt on your PC or something through
another I/O device on your PC, like the control lines on a parallel
port can be used to generate interrupts if you write the code for it.
This would have to be done in C though and would need to be on an O/S
that allows you to generate interrupts from a regular user
application, i.e. Win95 or 98 would probably work wheras NT would not
unless you wrote your own kernel mode device driver.
Douglas De Clue
ddeclue@bellsouth.net
wisam wrote in message news:<506500000005000000A38C0000-1027480788000@exchange.ni.com>...
> Hi :
> my PCI-4451 ..
ut
(2,809 Views)
