I have a problem with MAX reading GPIB instruments. It will not show them there but when I open a program the device will go in remote. So basically when I scan for instrument nothing comes back. This PC use to work just fine.What is my problem?
There are some third-party instruments that will not show up in MAX, but you can still communicate with them through the GPIB card. When you say that the PC used to work just fine, I am not sure if you meant that it worked with these specific instruments. If not, then it may be that these instruments will not be detected in MAX.
If these instruments have been successfully detected before, then it is very possible that it is a driver issue. I could email you a program that may help you with the uninstall and reinstall process. If you are interested in this program, please post your email address so that I can send it to you.
John M.
(2,343 Views)
