I have got iviPwrMeter Initialize.vi error!
    I am new to use IVI driver. I have configuration agilent U2001A Power sensor in MAX. Then I tried to initialize with labview and I got the error.
(3,325 Views)
Accepted by topic author tin_win
What is the driver version you are using?
(3,305 Views)
Hi Muks,
             I am using AgilentRFPowerMeter_3_3_7_0 IVI driver and IVI Compliance 3.3. I also attached untitled2.vi.Thanks for your reply.
Tin
(3,299 Views)
Why have marked my reply as the solution. Marking the thread as solution will invite lesser hits.
(3,285 Views)
I asked you the question to confirm whether the driver you are using is compatible with your device. Have you confirmed that?
(3,284 Views)
Hi Muks,
             I found out the error. The driver is not support in  Interchange Check. When I removed Inerchange Check tick in initialization Options in MAX, I can commnicate with the device. Thanks a lot!
(3,271 Views)
