12-02-2009 10:17 PM
I am new to use IVI driver. I have configuration agilent U2001A Power sensor in MAX. Then I tried to initialize with labview and I got the error.
Solved! Go to Solution.
12-03-2009 04:38 AM
12-03-2009 06:04 AM
Hi Muks,
I am using AgilentRFPowerMeter_3_3_7_0 IVI driver and IVI Compliance 3.3. I also attached untitled2.vi.Thanks for your reply.
Tin
12-03-2009 07:21 AM
12-03-2009 07:24 AM
12-03-2009 07:48 AM
Hi Muks,
I found out the error. The driver is not support in Interchange Check. When I removed Inerchange Check tick in initialization Options in MAX, I can commnicate with the device. Thanks a lot!
