I have problems to get information from Arduino GPS Shield to Labview
Hello, i'm trying to get information from my Shield GPS but i don't know how get it in Labview, someone can help me o tell how i can do it, thanks everyone. This is the shield.gpsshield1.jpg
Message 1 of 29
(6,828 Views)
That image is of no help at all. Typically, all you would need is the VISA serial functions if your arduino sketch is writing to the serial port. Look at the Linx toolkit examples or the serial examples that come with LabVIEW. If you don't know how to program the arduino for serial, this is the wrong board.
Message 2 of 29
(6,815 Views)
I was trying with the next code, but it doesn't work for me.
Message 3 of 29
(6,811 Views)
Sorry, I'm posting from phone so I can't look at it. Can you post an image of the block diagram? Please provide the error code that you are getting.
Message 4 of 29
(6,803 Views)
This is the code my friend. This module works with NMEA protocol, but i don't know if LAbview work with.cpdigo.PNG
Message 5 of 29
(6,792 Views)
LabVIEW works fine with nmea as long as it's programmed correctly. Because everything is buried in a subVI, it's impossible to say what is going on. I would suggest opening the subVI and probing the output of the v actual VISA Read to see what, if anything, you read. Any terminal emulation program can be used to read the arduino so you might do that first to verify that it is sending.
It will still be helpful to know what error message you get.
Message 6 of 29
(6,788 Views)
Hi, i was trying with it, because i have mounted gps shield over arduino board and it's works with NMEA protocol, i got it, but doesn't works 😕cesar.PNG
Message 7 of 29
(6,761 Views)
What exactly doesn't work? Your wiring of the VISA Resource to the nmea function looks wrong. Please probe the output of the read function and report what it is and please provide the error codes I've asked for three times now.
Message 8 of 29
(6,750 Views)
Did you take the advice you were just given  and decide to not post the useful information or opt to show an irrelevant screenshot rather than make an attempt?
Message 9 of 29
(6,746 Views)
Hi friend, the program doesn't works it wants to begin but don't, and i have problems like this, many problems problema.PNG
Message 10 of 29
(6,732 Views)
