I have problems to get information from Arduino GPS Shield to Labview
Read Dennis' message again.  Where he said VISA resource going into the NMEA function looked wrong.
You fed a purple wire in and it caused a coercion dot.  Meanwhile, almost all the other functions are working with a pink cluster wire going into the function.
Message 11 of 29
(2,874 Views)
You STILL have not said what it is you are reading. Have you don't any debug on the arduino ade? Is it sending anything at all?
Message 12 of 29
(2,873 Views)
I'm getting information from an Arduino GPS shield and it works with NMEA protocol it's beacause i'm using it, idon't know if i'm doing rigth or not, now i don't have problems but it don't read anything, someone can help me? This is the .vi
Message 13 of 29
(2,865 Views)
Are you reading any of the messages?
You still haven't tried wiring the pink cluster into the top left of Get GPS Data instead of the purple VISA wire!
Message 14 of 29
(2,863 Views)
Not reading the messages and not answering the
questions is NOT the way to get help. I'm giving up.
Message 15 of 29
(2,857 Views)
So sorry, i don't understand what you want to say, i don't understand english so good, i'm doing what i think you say, excuse me. i did it, but i don't have any information from my GPS shield.Capture.PNG
Message 16 of 29
(2,851 Views)
Now you've fixed the coercion dot on the upper left corner.  Why do you have purple wire where it is now?  You have a coercion dot there.
Message 17 of 29
(2,837 Views)
I am connecting the Read buffer from Arduino with Sensor Data from NMEA, i don't know if i'm doing rigth, but i can't get any information 😕Capture.PNG
Message 18 of 29
(2,832 Views)
Once last attempt to get you to provide some actual information that might help. Probe the output of the read. Or, right click on the output of it and select Create indicator. Run the VI do there is data in the probe or indicator. Attach an image that shows the content of the probe/indicator. You may In fact be getting data but In the wrong format. Your arduino ade should also show the data that the arduino is sending. Worry about the correct format only once you know that the arduino is actually sending.
Message 19 of 29
(2,820 Views)
i've done everything, but i believe i'm not reading anything with arduino block to read, this is the result from Read BufferCapture.PNG
Message 20 of 29
(2,795 Views)
