10-24-2011 10:35 PM
Hello
I am updating last year control software to include another module but this time on a new chassis. I am not seeing communication from RT Controller which is NI 9012 and the chassis is NI 9112 purchased two months ago. Before I go deep into software to see if there is a problem with the software I want to make sure there is no hardware or driver issue.
The software installed on the RT controller is NI RIO 3.6.0 Jan 2011 and I also have Real TIme 10.0.1
I dont have NI Time syns and Industrial Communication for Ethernet/IP 1.1 adds-on and I dont require it because I am using DMA FIFO to stream data from FPGA to Host and I am not using other PLCs, ,
I have BIOS 3.18 currently installed on the controller.
Is it all ok?
Kind Regards
Austin
10-26-2011
05:43 AM
- last edited on
09-08-2025
02:55 PM
by
Content Cleaner
Hello Austin,
Below I have listed a few things that might be causing the issue plus a few questions if the first few items do not resolve your issue:
1) Here are a few links that can confirm the software and driver compatibility:
Minimum versions of LabVIEW, Realtime and FPGA and NI RIO version you need to use with the 9012 and 9112:
LabVIEW - 8.6
Real-Time - 8.6
FPGA - 8.6
NI RIO - 3.1.0
You can find these at the below link:
ftp://ftp.ni.com/pub/devzone/tut/crio_software_versions.htm
2) There is also minimum requirements for NI RIO 3.6.0, you need to be using either LabVIEW 2010 SP1 or LabVIEW 2011 SP1 as shown in the below link:
3) Another thing to check is that NI RIO is the same version on the cRIO and on your PC, these must mach, ie 3.6.0 on cRIO and 3.6.0 on PC/Laptop.
Now a few questions if the above has not worked:
If you reply to this post with answers to the above questions I will then be able to better diagnose your issue.
Kind Regards
10-26-2011 06:43 AM
Hello Dan
Its all sorted now. I needed to disable firewall for Network stream communication
Kind Regards
Austin
