I have sampling rate issue on extracting data from 1D Array of Cluster of 2 Elements.
Any update?  I'm curious about how things went/are going....
Message 11 of 13
(565 Views)
Sorry for late responding. I was really busy with some other experiments. Recently I received  an email for the manufacturer of the measurement equipment (sm130). It is as below.
"Thank you for your email.  The sm130 is designed specifically for measuring shifts in peak wavelengths of ~250pm-wide-FBGs at 1kHz.  The intensity measurement is not calibrated.  It's only presented (at 10Hz) to help the user to optimize gain levels for FBG wavelength.  I'm afraid that the measurement you need is not a good match with the engineered purpose of the sm130."
I couldn't understand what he is talking about exactly. But I think the reason why I got the error message was because of limitation of the equipment. Can I ask some more questions after clearing some issues about the equipment? Thank you for your help.
Message 12 of 13
(561 Views)
Hi Abebae,
I think what they are saying is the that sm130 is not designed to measure intensity specifically, heance the "not calibrated" comment. A general instensity is required however because intensity is what determines where a peak exists.  When you change the gain, the instensity will change which allows you to see the signal more clearly and obtain a more accurate wavelength reading.  Does that help clear it up?
Message 13 of 13
(544 Views)
