I have to raed a "text file" with numbers that was seperates by commas & linefeed, how can I split them into an 1D-array of float numbers
I attach that text file with the above-mentioned, someone can help? Thanks
(3,244 Views)
1) Read in file with "Read from Spreadsheet File.vi" (on File I/O palette) with delimiter set to a comma
This will get you a 2d array with your numbers in it with a final column of zeroes (your file has lines which end in a comma followed by linefeed and carriage return which in spreadsheet terms is assumed to be an empty column)
2) Remove the column of zeroes with the "Delete from Array" function (Array palette)
3) Reshape the array from 2d to 1d with Reshape Array function (Array palette)
Example vi (LabVIEW 6.1) attached
Ian Bell
(3,245 Views)
Hi Iangbell,
Thank you for your excellent advice (even I could not see your file (mine is 6.0 not 6.1). But by following your steps, I am able to do as you adviced beautifully.
Thank you very much!
(3,244 Views)
I have a similar situation. Instead of displaying all the data at once I want to step through the data and compare each number with another number. Here is an example of what i am talking about. Lets say my text file contains the following
12345
56789
98765
54321
I want to go through each of these line and compare each number to a number inputed by a user. How would I step through the array?
(3,053 Views)
Use a For Loop with auto indexing enabled.
Message Edited by AndrewAlford on 03-02-2007 12:13 PM
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(3,047 Views)
