I kept getting this message (issue) every time I open Raspberry LabVIEW project. Can someone please help?
Below is the error that I kept getting. It would show up then my project would close. I can't even get the job done.
Raspberry pi LabVIEW project:
How do I go about solving this issue? Does anyone know?
(1,801 Views)
Accepted by topic author GRCK5000
Go to this folder:
C:\Users\<your user name here>\Documents\LabVIEW Data\LVInternalReports\LabVIEW\22.3.1f8 (32-bit)\
Find the folder there that matches one of the crashes.  You can match the date\time or the report ID.
Inside that you'll find a ZIP file, and inside that there is usually a few unhelpful DMP files but in some (not all) cases there will be a "lvlog.txt" file that contains some information about what was happening when everything crashed.  Looking through that file can sometimes point towards a corrupt file or maybe a toolkit you need to reinstall.
(1,762 Views)
Thanks Kyle! I think it's fixed by itself, but next time if it happens again, I'll refer to post.
(1,692 Views)
