Regarding the x-axis when performing FFT conversion of the waveform file of HWS file
Thank you for your continued support. I'm a beginner in LabVIEW. As shown in the attachment, I am creating an FFT conversion program by copying it, but after FFT conversion, the x-axis becomes the number of measurement points, not the frequency. Where is the problem? Please kindly advise.
If possible, write it in a graphical program.
Message 1 of 9
(1,830 Views)
The problem is that input to the FFT function is not a waveform data type, it is just an array of doubles which does not contain any information about the time domain of each sample in the array.
Try reading the data as waveform data type instead of Analog DBL from the HWS if you saved the time domain details. Essentially, all that you need is dt, i.e, delta time between samples in your waveform (inverse of your sampling rate of the waveform).
Santhosh
Soliton Technologies
Message 2 of 9
(1,821 Views)
Thank you for your reply.
I'm a beginner, so I kind of understand what you're saying, but would it be possible for you to give me more specific information?
Message 3 of 9
(1,799 Views)
Hi kozuka,
It really would help to provide your code, not just an image of code!
(We prefer code for older LabVIEW versions, like LV2019. There's a File->Save for previous menu item!)
Right now you provide just an array of samples to your FFT function: did you notice that red coercion dot? (Do you already learned what that coercion dots signifies?)
When your FFT function should work with respect to timing information then you need to provide that information - using the waveform datatype expected by this function! Read the help for the function…
Additionally you only use the "magnitudes" array after the FFT function, again a simple 1D array WITHOUT any timing/frequency information! Use the whole cluster coming from FFT as it also includes the f0/df values you need for senseful graphs…
Message 4 of 9
(1,787 Views)
Thank you for your prompt reply.
I will send you a vi file to convert to Fourier transform. I will also send you an HWS file as a sample. Although it is different from the image I sent earlier, it is a slightly modified version of the LabVIEW sample file. I kindly thank you.
Message 5 of 9
(1,778 Views)
Hi kozuka,
I don't have the HWS driver installed, but I still can show the concept of using waveforms:
Message 6 of 9
(1,773 Views)
Hi GerdW(Sorry if I got the name wrong)
Thank you very much for watching so enthusiastically. I tried following the attached instructions, but I am seeing a problem where the FFT graph part is not displayed. Thank you very much for your advice.
M.Kozuka
Message 7 of 9
(1,762 Views)
Accepted by topic author kozuka32
Hi kozuka,
When you want to calculate a FFT then you should use the FFT function!
See the attachment…
Message 8 of 9
(1,758 Views)
Hi GerdW
Sorry for the delay in replying. As you said, I was wrong. I sincerely apologize. I did exactly what you told me to do and was able to completely resolve the issue. Thank you from the bottom of my heart. That was a really big help.
M.Kozuka
Message 9 of 9
(1,732 Views)
