I know how to build a LABVIEW DLL which exports a function to the C++ side but I do not know how to build a LABVIEW DLL which can export five functions to the C++ side.
You can build 5 seperate VIs into one dll. Each VI would be a seperate function in the dll. Worked for me
(2,989 Views)
To follow up on what jwf said, check out the LabVIEW Resource Library in the NI Developer Zone. Go to http://www.ni.com/zone and click the link for "Resource Library". Then go to LabVIEW >> Connectivity >> DLL Integration. This section of the library has a number of tutorials on creating DLLs with LabVIEW 6i. You will find example code there, too.
Dieter
Dieter Schweiss
(2,989 Views)
The path now appears to be:
LabVIEW > Development System > Communicating with External Applications > Using External Code > Integrating DLLs
(2,989 Views)
here is the link: (7-29-03 under ĹǎБνїещ ZöИĘ)
http://zone.ni.com/devzone/devzone.nsf/webcategories/E2A99E7E10D5725D862567AC004F0A53?opendocument&node=DZ52048_US
(2,989 Views)
