I´m having problems with the speed of execution of a while loop that acquires data from a PCI6023E DAQ. LabVIEW 7.1 with W2000.The speed is VERY low.
I´m having problems with the speed of execution of a while loop that acquires data from a PCI6023E DAQ. LabVIEW 7.1 with W2000.The speed is VERY low. I acquire data from 6 channel (NIDAQmx channels) at the same time using a while loop and "AI Sample channels" VI. I have developed several applications with the same philosophy and I have not had any problem (with LabVIEW 5.1). Thank you very much.
(2,613 Views)
Hello Torre,
DAQmx is in fact more efficient than Traditional DAQ, so this behavior you describe shouldn't be the rule. I haven't been able to debug/check thoroughly your code, so here's what I suggest:
a) Try the W2000 option to give more time to background processes (see this link).
http://zone.ni.com/devzone/conceptd.nsf/webmain/28A6979ECA9A0CAF862569050053D92D?opendocument
b) Try with the LabVIEW supplied DAQ examples which do a similar task and test/compare their performance
c) Check with the LabVIEW tools where the time is spent (Profile VIs tool)
Hope this will help !
JorgeM.
(2,613 Views)
Hi Jorge, perhaps you speak spanish but I´ll write in English. I saw that it´s possible to modify the execution priority of VI-s.This property is in VI Setup -> Execution Options. I have never used this option till now and the application runs much more faster. I have not tried your tricks yet,since I have to go to the factory where it is installed, but I will try soon. Thank you Jorge
Ibon Torrealdea
(2,613 Views)
