I'm in need of a "container"
Hi all.
In my project there are 2 radio buttons. Each of them gives access to several controls (such as string, listboxes and checkboxes) which differ both in number and in type. What i would like to do is to make these controls visible or invisible in a single shot. To do this, i think i need to insert controls in 2 different "containers", each one related to a specific radio button. In this way i should be able to display controls i want, simply make the right container visible and the wrong one invisible.
Does anyone know how i can do this?
(3,032 Views)
Accepted by aRCo
It sounds like you want to put the related controls into a Cluster.
(3,030 Views)
In LabVIEW, a container is called a cluster. It is on the Array, Matrix, & Cluster palette. You would use the Visible property node. Just right click on the cluster terminal and select Create>Property Node>Visible. Change the property to Write by right clicking on it.
(3,028 Views)
How about a tab control?
Lynn
(3,012 Views)
use the suggestions from above and than connect your bool to a visibility property.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,005 Views)
