I'm reporting a fatal LV error.
The attached VI will crash LV2009 under WXP. The capital D format specifier (mistyped instead of d) is the culprit.
(3,078 Views)
I can confirm it does it on LV2009f2 on Windows Vista Home Premium as well.  It is a Windows level crash where Windows tells you there is an error and wants to open a debugger.  (But that actually didn't show anything.)  There is no report of any errors upon reopening LabVIEW.
(3,067 Views)
Interestingly enough, if you save it for 8.2 and run it under 8.2, 8.2 doesn't crash. Hmmm....
(3,046 Views)
Hey Kinnos,
Thanks for taking the time to point this out. The issue has been reported under Corrective Action Request number 194172.
Hope this helps.
-Ben
WaterlooLabs
(3,014 Views)
