I'm trying to build an unique 2d array:
It has 4 user inputs, x, y, width, height, width1, height1. What i'm trying to do is an array which is width by lenght in dimensions, but a small portion in the center (width1 by lenght1) consists of the y input, everything else x.
would be grateful for any ideas or solution..
(2,614 Views)
Here what you want, If I understand you correcly. But beware - I've maked this exaple without any testing for correct height/width values.
Hope this helps
(2,614 Views)
Awesome, Merci beaucoup
(2,614 Views)
