I would like to be able to configure each group to a read interval. I've set the RSlink polled msg rate at 30000 ms but the opc client is forcing a read at a much faster rate, at least every second. I've tested with success the RSLINX OPC client to read every 30 seconds so I believe the problem is in the OPC client and not the OPC server. TIA, Craig
