I would like to know if labview can works with hp82335b interface
I would like to know if labview can works with hp82335b interface for instruments data aquisitions
(2,659 Views)
on following link: http://ftp.agilent.com/pub/mpusup/pc/old/hp_over.html
they say:
"The 82335 will not work under National Instruments Labview in any way, shape, or form. In general, it will not work on any product that doesn't specify that it does work.
There are no plans for any improvements to this product and no engineering resources on it."
In case this is true, you will go into trouble with
your card using LabVIEW.
Regards
wha
(2,659 Views)
Did you have an answer about this question?I have a Hp82335b interface,too.I want to know if you resolve this question?
(2,659 Views)
