03-01-2012 01:40 PM
So I accidently saved over a Labview example code for one of the compactRio Module 9233. I was wondering if i could either have a copy or some tell me how to reload the example codes.
Solved! Go to Solution.
03-01-2012 01:50 PM
Repairing your LabVIEW installation might fix it, but it would probably be easiest if you post the specific VI or example you need, and your version of LabVIEW, and ask if someone can upload it or send it to you.
