I need SRS Function in LabView.
Hi, everyone.
I am looking for SRS(Shock Response Spectrum) VI.
I have SRS subroutine in C language. But I can not handle how to convert it
to Labview.
Could you help me?
Jinho,OH
(4,259 Views)
You can put your C code into a Code Interface Node. You have to create a .lsb
file with a C compiler and select it as the resource file for the Code Interface
Node. There are documents about this on ni.com.
"Jinho,Oh" wrote:
>Hi, everyone.>>I am looking for SRS(Shock Response Spectrum) VI.>>I have
SRS subroutine in C language. But I can not handle how to convert it>to
Labview.>>Could you help me?>>Thanks>>Jinho,OH>>
(4,259 Views)
The best way that I have found for incorporating "Legacy" C programs is to
use Code Interface Nodes. That way you can just import the C code and use
it pretty much as is. NI publishes an entire manual on CIN's. They're still
a little tricky, but for a lot of things, much easier than trying to do it
all in LV.
Rob
(4,260 Views)
In case anyone stumbles upon this old thread while searching,
SRS (Shock Response Spectrum) is now offered in the Sound and Vibration Toolkit - http://sine.ni.com/nips/cds/view/p/lang/en/nid/3122
(4,033 Views)
