Where do I get my TestStand VIs in LV8.5?
I just upgraded to LV 8.5. I had already upgraded TestStand to 4.0. LV does not have the TestStand VI's. Where do I load them from? The TestStand Device Drivers CD? Or do I repair TestStand 4.0?
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,077 Views)
Are you saying that you don't have a Test Stand functions palette for the block diagram?  They should load once you install Test Stand and then reboot.  They should be in the addons section of the functions palette.
Message Edited by tbob on 09-11-2007 03:55 PM
- tbob
Inventor of the WORM Global
(3,077 Views)
Yes I do not have the TS pallete. TS 4.0 was installed first (before LV8.5) as it was released first. So do I need to install again or just do a repair? Or are the VI's on the TS drivers cd?
(3,071 Views)
My guess is that you should have installed Labview first.  Without Labview, the Test Stand installer would not know where to put the Test Stand functions since the Labview folder did not yet exist.  Now that you have Labview installed, I would think that doing a Test Stand repair might work.  The functions must be on the Test Stand CD, but I don't know where or how to install just that part.  Try running the test stand install again and do a repair.
- tbob
(3,066 Views)
I'll give it a try. Just tring to get my LV environment just the way I like it at the momentSmiley Wink
(3,064 Views)
I reinstalled TestStand 4.0 and now the TS palette appears in LabView 8.5. Thanks
(3,042 Views)
