I need help please!!
Show us a screen grab of your Windows Device Manager and NI-MAX like I posted above.
=== Engineer Ambiguously ===
Message 11 of 12
(802 Views)
Accepted by Ozvaldo5
Try to make sure your Device Drivers / NI VISA is Installed Properly in your system. LabVIEW Should be able to detect the plugged in Ports when all the drivers are installed Properly.
Try to share the snippet of NI MAX Driver details/ Device manager Details.
Message 12 of 12
(777 Views)
