I need help please!!
Show us a screen grab of your Windows Device Manager and NI-MAX like I posted above.
=== Engineer Ambiguously ===
Message 11 of 12
(1,037 Views)
Accepted by topic author Ozvaldo5
Try to make sure your Device Drivers / NI VISA is Installed Properly in your system. LabVIEW Should be able to detect the plugged in Ports when all the drivers are installed Properly.
Try to share the snippet of NI MAX Driver details/ Device manager Details.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 12 of 12
(1,012 Views)
