I need help to control a Golander pump through MODBUS protocol
Hi, I am new to LabVIEW. And I am trying to control our Golander pump through LabVIEW. I wrote the following program in LabVIEW but the pump doesn't do anything. Can someone help me check the code?
(934 Views)
Hi qsua
Here are a few things you can check:
I assume you're communicating with RS-485,
- check the serial port configuration
- try to read data first from the Modbus device to test that the communication is going through from the input registers (for ex 1023 product information)
- don't use loop while, just use one single strip : serial configuration, write, wait a few milisseconds( you need to try a number you need to wait for hthe instrument to respond) then read it.
- then try to write data into the register you need. Sometimes to write one command you may need to send multiple messages to the instrument obey you.
RKo
(882 Views)
Hi Rko,
Thank you for your reply. I am communicating with RS-485.
- By test through the input registers do you mean the following? I have attached figures and the vi for you to check.
- I have removed the while loop but still did not let the pump run.
- I am not sure if the processes I am using is the right ones to use.
(867 Views)
