Camera in Use error when using Reset Camera VI IMAQdx
Hello. I have been dealing with a driver switching issue for a program that requires switching from a company specific camera driver to the NI IMAQdx drivers and vice versa. I can switch between them, but when switching back to the NI IMAQdx driver I have to power cycle the camera for it to work (I get a timeout error when attempting to take a snap or grab otherwise). There is a VI in the vision toolkit called "Reset Camera VI".
My issue is when I run the vi (entering the session for the specific camera), and then try to use the camera I get a "Camera is in Use" error. There doesn't seem to be much documentation regarding this vi, so any advice on how it works or what it specifically does would be appreciated.
LabVIEW 2023 Q3 64 bit
NI Max 2023 Q4
IMAQdx 2023 Q1
Windows 10 64 bit
Message 1 of 1
(1,085 Views)
