Labview 2012 and DDE
I am looking for the DDE library @ labview\vi.lib\platform\dde.llb with no success.  It appears that I do not have that library.  Is there any way I can get dde.llb elsewhere?
Thank you in advance,
-Jason
Message 1 of 16
(9,069 Views)
Hi Jason,
First try to repair your LabVIEW software by going to add/remove devices in the control panel. If you right click on the "national instruments software" and choose "uninstall/change",  you can choose repair option. This process will look for whatever is missing in your LabVIEW and add it. Good luck
Message 2 of 16
(9,030 Views)
@ Edna, I tried repairing but still did not get the dde.llb.  Is it possible that my trial version does not come with it?
In any case, before I can purchase full Labview I need to know if my current VI works.  It requires the dde.llb, can someone provide that to me?
Thanks in advance,
-Jason
Message 3 of 16
(8,999 Views)
I have LabVIEW 2009, and dde.llb is there.
Message 4 of 16
(8,995 Views)
Could you attach that library for me so that I can put it in my directory?
Message 5 of 16
(8,989 Views)
Jason what LabVIEW version are you using? We first need to make sure that version includes dde library. Thank you!
Message 6 of 16
(8,955 Views)
I am using Labview 2012 (64-bit) version on Windows 7 Professional (64-bit).
Message 7 of 16
(8,944 Views)
Accepted by topic author jasonhk1020
Hi Jason,
I beleive that you can get the library by uninstalling/reinstalling your LabVIEW from either the DVD you got or by downloading it again from our website(link included). Unfortunatly, I can't just post it here for you.
https://www.ni.com/en/support/downloads/software-products/download.labview.html
Message 8 of 16
(8,914 Views)
Hi Edna,
I figured that the dde library wasnt present in the 64 bit version.  I installed the 32 bit version and the dde library came with that.
Thanks for your help.
-Jason
Message 9 of 16
(8,903 Views)
Awesome Jason. Glad that worked out for you!
Message 10 of 16
(8,882 Views)
