I need help w/ speed up parsing of spreadsheet string
Replace the remove comma and remove space with this (see image below).  See your code (attached).  You can do something similar for the while loop to the right of your code.  Try to avoid loops. 😉
Message Edited by JoeLabView on 09-14-2007 07:53 AM
Message 11 of 35
(1,910 Views)
much obliged, thank you kindly for thelp!
Message 12 of 35
(1,895 Views)
no problem (thanks for the stars 🙂 )
did you notice a speed difference? 😉
Message 13 of 35
(1,894 Views)
The speed difference is huge, it is just what I was hoping for!  Thanks again!!
Message 14 of 35
(1,892 Views)
One more question, I did as you suggested and replaced the while loop with the search and replace string.vi, searched for \s and replaced with the tab constant.  The output is a little different than what I was seeing before.  When I view the '\' Codes Display instead of the normal text the old slow version has this output:
 TRIAL\tLOG\r\n\r\nProject\tNumber:\t063905\r\nProject\tTitle:\tLARC\tAnnex\t\r\nProject\tScale:\t1:240\r\n\r\n
and the new fast version has this output:
TRIAL\sLOG\n\nProject\sNumber:\s063905\nProject\sTitle:\s\sLARC\sAnnex\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\s\nProject\sScale:\s\s1:240\n\n
You can see the difference.  Do you have any thoughts on how to replace all \s with \t as it looked previously?  Thank you in advance!
Message 15 of 35
(1,890 Views)
Actually, it looks like the issue is slightly different.  I hadnt se the replace all boolean to T, after doing this the output looks like:
TRIAL\tLOG\n\nProject\tNumber:\t063905\nProject\tTitle:\t\tLARC\tAnnex\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\t\nProject\tScale:\t\t1:240\n\n
Which is one step closer, but I need to remove the duplicate tabs, so that I only have one tab seperating each column.  That should give me a result equal to the old version:
Any thoughts?
Message 16 of 35
(1,892 Views)
it looks like Search and Replace Pattern.vi may do the trick, I am going to play around with this.
Message 17 of 35
(1,890 Views)
Yes, it's good to experiment a little..
Basically, if you replace all your \s (space) with \t (tabs), then you end up with a whole bunch of tabs.
There are other tricks..  If you get stuck, post your code or an image or that section and we can offer some suggestions.
Have fun!! 😄
RayR
Message 18 of 35
(1,885 Views)
I have found that using the Search and Replace Pattern.vi slows the program back down, any suggestions on how to counter that?
Cheers!
Message 19 of 35
(1,879 Views)
You mean after removing the while loop?
Message 20 of 35
(1,870 Views)
