I need help with array leds
How to do this loop?
Message 1 of 29
(6,973 Views)
Your VI has a password, thus we cannot see what you want to do and what loop you are talking about.
Message 2 of 29
(6,963 Views)
Yes, for that reason I want know how to do it.
Message 3 of 29
(6,956 Views)
What is "it"?
To replicate the operation of the attached VI, start with an initialized 2D boolean array in a shift register and replace one element at a time with a TRUE value. You can calculate the current position based on the iteration terminal and some simple geometry.
We won't do your homework. What have you tried so far?
If you get stuck, show us what you have it we might be able to point you in the right direction.
Message 4 of 29
(6,936 Views)
Maybe this attached file will get you started, it took me all of 12 minutes!
Message 5 of 29
(6,935 Views)
The LED needs to move in a spiral, not diagonally across, so the solution would need little bit more code. 😉
Here's my version, you can even select the starting direction. 😄
(The password is pretty long...)
Message 6 of 29
(6,924 Views)
Drat, now I must one-up you altenbach! Pretend this is a LabVIEW VI and not a YouTube link:
http://www.youtube.com/watch?v=f1YNyQqbiF0
Message 7 of 29
(6,916 Views)
I do not want to do my homework, just needed help figuring out how to begin.
With what you said and I have an idea, I appreciate it.
And I apologize for my bad English, I only know Spanish.
greetings and thanks.
Message 8 of 29
(6,911 Views)
You could do it using a state machine like the attached VI.
You have posted this question twice.  Please don't do that, it could waste peoples time.
Kind Regards
Lewis Gear CLA
LabVIEW UAV
Message 9 of 29
(6,887 Views)
Thank you!
I was do the program, but I don´t want the 4 cases, I just want 2 cases; up and down, and that the enum be in the same fornt panel, but I can´t, can you help me?
Message 10 of 29
(6,874 Views)
