I need help with array leds
You got a working draft version earlier. What else do you need?
Once you fully understand the code and the purpose of all four cases, you could try to come up with ideas to improve it.
Here is a quick cleanup of Lewis's version, eliminating some of the duplicate code that I mentioned earlier. Maybe it is now easier to understand. The original also had one too many iterations. (The typedef is still the same)
As I said, it is possible to create a solution without the use of any case structures.
That would be a good exercise! See how far you get 😄
Message 21 of 29
(3,391 Views)
And here's a hint to use some of the inherent symmetry in the directions. 😄
Message 22 of 29
(3,386 Views)
Thank you!!
I´ll try to modify the code to add more things and I´ll send you for suggestions. 🙂
Message 23 of 29
(3,378 Views)
I like the mods.  I will hopefully spot things like that in future.
Thanks for the code reviewSmiley Happy
Lewis Gear CLA
LabVIEW UAV
Message 24 of 29
(3,340 Views)
Just for a very different perspective, an interesting solution involves complex numbers. It always helps to think outside the box. 😄
It is useful to know that a multiplication of complex numbers corresponds to a rotation.
(Less code overall! No case structures! Only a single instance of "replace array subset"! 121 iterations on the FOR loop!, etc.)
Remember, your teacher also reads these forums, so I would not use this directly, but maybe you could use some of the (non-complex) ideas in your solution. You could try to implement something similar without using complex numbers.
Message 25 of 29
(3,321 Views)
interesting code....good job!   Smiley Happy
Message 26 of 29
(3,313 Views)
That is the best VI I have ever seen!
Message 27 of 29
(3,288 Views)
Awesome! Smiley Very Happy
Br,
/Roger
Message 28 of 29
(3,261 Views)
Thank you very much. I know that my tecaher can see this forum, I´ll change somethings in code.
Message 29 of 29
(3,242 Views)
