I need rotary potentiometer in labview.how can i find this VI?
Hi my friends.
i attached my potentiometer's photo and i want to have something like this wich it's 2Pointer  change during changing Voltage.
How can i find VI like this one?
thanks alot .
(3,459 Views)
I am not sure what that device you showed wou be good for electrically but here is what I came up with.
As you turn a single knob R1 increases and R2 decreases
=== Engineer Ambiguously ===
(3,424 Views)
thank you.can you send me an older version?i have 2007 version
(3,413 Views)
Here's a couple pictures you can follow
Block DiagramPanel
(3,396 Views)
thanks.
can i make it like 2 rotary potentiometer .  METER in labview is something like that but i can't rotate it 90 degree(i want 2 vertical rotary (180 degree span).
(3,392 Views)
I think you are going to have to create a custom control to get exactly what you want.
It's kind of cheating but you could try stacking two "knobs" and play around with making parts of one transparent so it looks and acts like one "knob".
Then using property nodes you can adjust the scales and make then inversely track each other.
(3,348 Views)
