I need to be able to delete a user from a previously created database thanks...
For example I already have the database created but now I want to be able to add and delete users from this database ...
(3,502 Views)
Click on the "add" and "delete" buttons as needed.  You have to give us more info than that.  😉
Bill
CLD
(Mid-Level minion.)
(3,494 Views)
Yes I agree with Billko.
(3,432 Views)
Maybe you could try adding some images, or sending your VI.
(3,428 Views)
(3,401 Views)
Accepted by Anibal1994
Search for the name in column 0 (through Index array and Search 1D array), remove the row with Delete from Column, save to file.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,387 Views)
You could make an outline of how to do.,,, Thanks
(3,381 Views)
