I need to be able to delete a user from a previously created database thanks...
For example I already have the database created but now I want to be able to add and delete users from this database ...
(3,506 Views)
Click on the "add" and "delete" buttons as needed.  You have to give us more info than that.  😉
Bill
CLD
(Mid-Level minion.)
(3,498 Views)
Yes I agree with Billko.
(3,436 Views)
Maybe you could try adding some images, or sending your VI.
(3,432 Views)
(3,405 Views)
Accepted by topic author Anibal1994
Search for the name in column 0 (through Index array and Search 1D array), remove the row with Delete from Column, save to file.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,391 Views)
You could make an outline of how to do.,,, Thanks
(3,385 Views)
