I need to blink the Datapoints in XY graph.
I'm using a XY graph with 2 waveform in it. One of it has Data points shown, and I want to blink those particular Data points. Help me out in blinking those data points. I tried blinking with Property node but the other graph without the data points are blinking,
Thanks for helping.
Message 1 of 20
(4,767 Views)
Use a loop with a suitable delay and alternatively update the graph with and without these data points.
Message 2 of 20
(4,760 Views)
It's real-time plotting, so values will change at some interval according to the delay. But I need these data points to blink.
Message 3 of 20
(4,756 Views)
My method will still work if done right. What is your definition of "real time"?
Can you show us a simplified version of your code using e.g. simulate data?
Message 4 of 20
(4,737 Views)
Attached.
Message 5 of 20
(4,729 Views)
These are just pretty useless images, not code. What part should blink and how fast? What is the loop rate?
Message 6 of 20
(4,705 Views)
The code is very lengthy, so I am not able to upload all. In that Front panel, graph is shown. I want to blink those points which is Red in color. Is there any way to do that?
Message 7 of 20
(4,701 Views)
Yes, of course there is.
(But we cannot help you unless you answer our questions)
Message 8 of 20
(4,694 Views)
Loop rate is 1sec, So the values change for every second. I want to blink the Data points every time when the values change. I mean to say Loop rate=1sec and blinking rate should be 1sec. Thank you
Message 9 of 20
(4,691 Views)
Do I see a hard wired endless loop??
Remember stopping a vi with the abort button is like stopping your car with tree on the road 😄
You can use the poperties of the graph to change the colors of the plot points ...
see example...
EDIT:   on every interation the color is swapped
Greetings from Germany
Henrik
LV since v3.1
Message 10 of 20
(4,690 Views)
