I need to blink the Datapoints in XY graph.
I'm attaching the VI. There is 3 more SubVI's. If its required then I will attach it.
Message 11 of 20
(2,128 Views)
Here is a horrifically messy implementation of Altenbach's solution, along with an example snippet (slightly less horrifically wired) showing the same idea. I believe he has a cleverer way of detecting odd and even iterations, but I don't remember it. If you're good with bit-shifting, that might be an alternative (but I guess then you need number to boolean, or a case structure instead of Select).
Edit: Perhaps it's to take ('i' AND 1)? That produces a flickering 0,1 pair that can be compared with 0.
GCentral
Message 12 of 20
(2,113 Views)
no need to swap data
and for a 1s interval I strongly recommend only a changing color..
Greetings from Germany
Henrik
LV since v3.1
Message 13 of 20
(2,110 Views)
using plot visibility.pngYou can also use the plot visible property to make it blink.
Ben64
Message 14 of 20
(2,087 Views)
I am attaching the screenshot of Front Panel.
In those graphs, Data points are represented red in color. I want to blink those dots whenever the real time values changes. ie. 1sec. I can't attach my VI flie cause I'm using SQL server for fetching data. So its of no use if I upload my VI. Thanks in Advance.
Those connecting lines are blinking using Property node but i want those dots or data points to blink! Thanks.
Message 15 of 20
(2,068 Views)
My guess: You choosed the wrong property 😄
In my picture earlier I posted a picture of the properties you need to choose:
first you need to select the active plot (starting with zero, so I assume in your picture the second plot (No.1) is the red one.
next ist the Plot>Fill/Point Color property
Henrik
LV since v3.1
Message 16 of 20
(2,065 Views)
To have only the data points blinking you need to have 2 plots. One with no interpolation between the data points and the other one with interpolation but with point style set to none. You can then have only the data points blinking.
Ben64
Message 17 of 20
(2,045 Views)
Accepted by topic author dhanushmh
Ben64
No, no need for a second plot !  😄 😄
Even no need for an graph update
EDIT: Version 2 with a XY graph... makes no difference 😉
Henrik
LV since v3.1
Message 18 of 20
(2,038 Views)
Great, you can select T (for transparent) as one of the colors,  that way it will replicate an on/off blinking.
Ben64
Message 19 of 20
(2,032 Views)
Or change the point style property , or .... or ...
Henrik
LV since v3.1
Message 20 of 20
(2,024 Views)
